TPS - Vette vs. F-Body
Old Nov 4, 2005 | 04:20 PM
Frizzle Fry's Avatar
Default TPS - Vette vs. F-Body
I pulled the TPS off a vette TB and mounted it to a Camaro TB. First thing is that it mounts on the other side of the TB, so the open and closed positions are opposite. Just wondering if the ECM programming accounts for this or if I need a manual TB TPS.
Second issue is that the plugs are different. I ohm’d out every pin on the harness (camaro version) and the TPS plug is a round 3-pin. The vette tps has a flat socket.
Just wanted to do a pulse check here before buying a manual TPS.
