5.3l in 2nd gen cam help!!!!
Old Nov 8, 2005 | 02:27 AM
sstz28's Avatar
Default 5.3l in 2nd gen cam help!!!!
ok guys i need some help. my buddy is doing a 5.3l/ 4l60e swap in his 2nd gen. he wants a good cam with good power and lopey. he is going with true duals and loves the way texas speed cams sound. what cam would u recommend. also what fuel pump and fuel tank modifications will he need 4 the swap. can he use the truck fuel pump
Old Nov 8, 2005 | 07:33 AM
Schitzo's Avatar
don't know much about the cam question but I can help with the fuel part. For a second gen there are two ways you can go. One, find a 3rd gen fuel pump/sender assembly (should be easy to find in a junkyard). This will mount right up to the existing pickup hole on the 2nd gen tank. However you need to find a way to incorporate a baffle in the tank to avoin fuel starvation. 2nd way( which is the way I am going with my 71 LS1 swap) ...use a in tank setup from tanks inc. you have to cut you tank and fabricate a plate to mount the assembly on the tank. i will post pics here later this week when I am done with my tank.
Old Nov 10, 2005 | 09:26 AM
LVSTOGOFST2002's Avatar
the bad ***, off the shelf cam for the 5.3, tried and true... is the Thunder Racing TR220 specs are : 220/220 .551/.551 112, this cam with a stall converter and 4.10's in a 4400lb truck, is in the 12's on like 3-4 trucks. It's easy to tune, lopes great, and in a lighter car..... will be just sick. if you want fast and easy..... that's the one. the only time i'd go smaller, would be with a heavier vehicle. if you want more input on this, pm me.... i've got tons of info, i've been cam shopping for a month now. I've decided on a custom grind, but for your application...... this is the one. good luck, and have fun
Old Nov 10, 2005 | 12:32 PM
LIL SS's Avatar
Moderator
For the fuel system you could also sump the stock tank and run an external high pressure fuel pump with a fuel pressure regulator close to the tank. Reason for putting the regulator close to the tank is so you don't have a return line going the length of the car.
Old Nov 11, 2005 | 05:11 PM
71Formula's Avatar
I've been looking into the 5.3L swap in my 71 Firebird for some time now. The motor is a real tight fit under the hood as far as hood clearance goes. Does your buddy plan on using a cowl hood for clearance or what is his plan there? I'm trying to decide on a 5.3 or LS1 5.7. 5.3L is way cheaper but I think I'd have to change hoods.
Sorry if I got off topic a bit. Just thought you guys might be able to help.
Roy
Old Nov 13, 2005 | 07:49 PM
sassygrlta99's Avatar
he is going with a 2 1/4 cowl hood. also how bad will his low end torque with that ls1 manifold. will a stall and gears make up for it.
