Ls1 6.0 liter swap to a 1994 Camaro. need some help on this one!!!!
I have done a search on this thread and came back with a little more info then I had before. One question I have yet to get answered is if a 4l60e out of a 94 Z-28 with work with this engine or will it have to be swapped out. Also, the wiring on the lt1, will it work or not. And lastly, do I need a different computer, or just a reflash? I have these available thru where I work for a great price. They are all zero mileage takouts. never really taken out cuz they were never installed, or run. I have the ability to get the parts because of my working at a late model salvage yard. This is a swap I really want to do, both for being unique, and the ability to increase the HP as I feel the need in the future. I will put a cam and intake on this engine, probably the ls6 intake and various other things before i drop it in. such as headers. Anyinput would be great. I know it can be done, but I just need a little guidence on the how part of it. Thanks in advance <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Also, the wiring on the lt1, will it work or not. And lastly, do I need a different computer, or just a reflash?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No......the wiring that you need will be a wire harness designed for the LS1, not an LT1 harness. You can splice the LS1 harness into the existing LT1 body harness. Also, the PCM for an LT1 and LS1 are not the same. You need the LS1 PCM.
the tranny will not work from your car, you must use a 4.8 5.3 6.0 or 5.7 gen 3 v8 tranny to bolt up but 6L's came with 4L80e trannies or 4l65s...
Jeremy
Jeremy
GM sells a flywheel and a special spacer to go on the end of the crank so you can mount an early 4L60e, th400, or th350 to an ls1. The part # for the flywheel is 12551367. The part # for the spacer and special bolts to install it is 12563532 and 12563533.
Thank you for the part numbers on the tranny stuff. That will help alot since I have already gone thru my tranny pretty well. Should I splice the harness into the LT1 harness, or should I be able to pull the entire harness with the LT1 out and use the new harness. Is that going to cause compatibility problems with my internal devices...like the speedo. I can get the computer, I have a harness out of a Silverado with a 6.0 or I can get a firebird ls1 harness. The motor is already in my possesion and being torn down so as to install the cam and have the block decked to fit the LS6 intake I have for it. Am I missing anything that anyone can think of, besides the spacer kit for my trans that I will go get this weekend.
dream1q, this might help you :
installing LS1 motor in 94 LT1 camaro :
1- I dont carry custom harnesses. Check my Links page for companies
that do.
2- Any 93-02 f-body radiator will fit.
3- Any 93-02 dual fans will work.
4- The ABS, fuel pump and lines all work. You will have to modify the
A/C
lines.
Mark Whitley www.hpsalvage.com
mark@hpsalvage.com 210-649-2554
----- Original Message -----
To: High Performance Salvage <mark@hpsalvage.com>
Sent: Tuesday, October 22, 2002 12:49 PM
Subject: Re: installing LS1 motor in 94 LT1 camaro
> thanks alot for the reply.
> 1- about the harness do you have custom harness that
> will work with my current gauges? how much does it
> cost?
> 2- about the LS1 radiator, will it fit the stock
> locatoin of the current radiator or there is any kind
> of modification to let it fit?
> 3- i will need LS1 radiator fans? right?
> 4- about the other functions like ABS, fuel pump, fuel
> lines, A/C lines...etc will they work or i need to
> modify or replace them?
> thanks.
> --- High Performance Salvage <mark@hpsalvage.com>
> wrote:
> > 1 - You can use the earlier transmission with a
> > special flywheel and adapter
> > from GM.
> > 2- You have to use the 98-02 front crossmember and
> > engine mounts
> > 3- Use the 94 transmission crossmember.
> > 4- The LS1 engine harness will have to be modified
> > so it will mate up to
> > your existing engine compartment and interior
> > harnesses. If you get a 99-02
> > engine, you will have to run a second set of sensors
> > in the engine to run
> > the gauges.
> > 5 - Any 98-02 mods will work, the frame of the car
> > didnt change.
> > From: Abdullah AL-Kandery <kandery@yahoo.com>
> > To: <parts@hpsalvage.com>
> > Sent: Monday, October 21, 2002 1:05 PM
> > Subject: installing LS1 motor in 94 LT1 camaro
> > > i own 94 LT1 camaro with 4L60E transmision. i want
> > to
> > > swap in an LS1 motor :
> > > 1- do i need the 4L60E of the LS1 or i can use my
> > > current 4L60E?
> > > 2- how about engine mounts? do you have them? and
> > how
> > > to weld them correctly so that i have no
> > vibration?
> > > 3- if i install the LS1 4L60E do i need to
> > fabricate a
> > > transmision mount for it?
> > > 4- what about the wiring harness and PCM and how i
> > > will keep the my 94 gauge cluster work correctly
> > with
> > > the new PCM?
> > > 5- will i be able to use the current 98-02 LS1
> > speed
> > > parts specialy headers, superchargers,
> > > turbochargers...etc? i mean will there be any
> > > body/frame/chassis interference with these parts?
> > > 6- please let me know the swap in detail and parts
> > > that i will need to do the swap. thanks
> > > Abdullah
> > > __________________________________________________
> > > Do you Yahoo!?
> > > Y! Web Hosting - Let the expert host your web site
> > > http://webhosting.yahoo.com/
> Abdullah
> Do you Yahoo!?
that do.
A/C
lines.
> cost?
> thanks.
> > from GM.
> > engine mounts
> > the gauges.
> > didnt change.
> > to
> > > current 4L60E?
> > how
> > vibration?
> > fabricate a
> > with
> > > the new PCM?
> > speed
> > > Abdullah
> > > Do you Yahoo!?
> Abdullah
> Do you Yahoo!?
I just finished putting an LS1 (1998) into a 1994 Z28 chassis. I had a donor car at my disposal, so I took the time to completly swap all three wiring harnesses (engine, front chassis, rear chassis), dash and gauge cluster. I looked into some splicing, but perferred to have a matched set so that engine matched all controls. Only had a few problems (connection to crank sensor), otherwise it started right up.
I'm sure someone said so earlier in this post, but you will need a new PCM to match the engine harness.
Feel free to email if I can be of help.
Thi thread is helping me out alot i have a LS6 that i can get for cheep and it is out of a corvett. I have a 93 camaro z28 is there any differences I will need to know. I havent yet bought the moter but am thinking about it very hard.
so this is what i will need!!!!!!
PCM
Wire harness
Spacer plate for my tranny
Do i need new gages???? Can i use existing sencers in the ls6????
What do you do for headers???
What did you do for Air box???
I have a 93 so my tranny is a 4l60 will that be ok?
Thanks for your help!!!!
PCM
Wire harness
LS1 sending units from a 98 F body will work with the LT1 gauges with a little wiring modification, your gonna need a F body harness though as the Vette harness is just too different.
Headers for any LS1 F body will fit.
You'll have to fab something there.
Actually the 93 cars had a kind of bastard 700R4 that won't work with the LS1 PCM. Your better off getting a LS1 4L60E, otherwise you will need a stand alone computer just to run the tranny.
Re'
Re'
The 93 is not a 700R4 it is the 4L60 not the 4L60E it just isnt controled by the computer. I am not 100% shere but i beleave that is what the camaro white book.
ok pulling up another old thread.
I see that the 4l60 is the same as the 700R4 in the 93.
and that wont work at all? I dont think there is any eletronics that control the tranny? i could be wrong. so couldent i just program the PCM so it will think that the tranny is working on its own???
