LS-1 Fuel Pump For Datsun 280Z
Guest
Posts: n/a
I aminstalling an LS-1 in a Datsun 280Z that is already fuel injected - AN6 supply and return lines. The Datsun uses a pump external to the tank and I would like to continue in a similar vein using a pump suitable to the LS-1 and it's ECM that can also be externally mounted to the tank.
Any suggestions? Things that I should be concerned about?
Thanks for your help.
Phantom
Phantom
Guest
Posts: n/a
Thanks for the info Mightymouse. anyone else out there have other suggestions? I did a search and really didn't find much on this - only about three threads.
Thanks again.
Phantom <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Thanks again.
