Street & Performance Motor mounts $90
Old Oct 30, 2002 | 02:06 PM
C4VetteLS1's Avatar
Default Street & Performance Motor mounts $90
I just ordered a set from them. They were $89.99 for conversion motor mounts to bolt right to where the original v8 went.
saved all the hassle of making them and hoping they fit.
in case anyone wanted to know:
http://www.hotrodlane.cc
Old Oct 30, 2002 | 03:31 PM
67ls1CamaroProject's Avatar
Default Re: Street & Performance Motor mounts $90
They are nice but then you have to move the alt and a/c up top with their $1000.00 bracket kits. I used motor mounts made by BRPhotrods.com. They position the motor a little further forward. Belt drive stays the same. Have to modify the oil pan to clear the steering link in a first gen camaro. Ohter than that, I like this method better. Cost is $170 for the pair.
Old Oct 30, 2002 | 03:32 PM
35thss's Avatar
cool thanks for info....couple questions....these are just plates for the stock mounts to bolt to, right? .. part number? pics?thanks!
Old Oct 30, 2002 | 04:45 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I bought a set of these when I started the 3rd gen project. http://www.speartech.com/coproj-1991ls1.html
They bolt to the four holes on the LS1 block using flathead screws and then allow you to bolt a standard 3 bolt SBC mount to them.
They would not work at all on our 91 Z28. Custom mounts was the way to go. On the other hand, they would probably work on a street rod application and probably some cars.
Mine are brand new and I'll sell them for $75 shipped if anybody wants them. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Oct 30, 2002 | 11:39 PM
N2TRUX's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 67ls1CamaroProject:
<strong>They are nice but then you have to move the alt and a/c up top with their $1000.00 bracket kits.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not always. We used the S&P plates on my 82 Blazer with the stock F-body brackets. We did have to mildly massage the S&P plates, and the a/c bracket, but it does work...
<small>[ October 30, 2002, 11:40 PM: Message edited by: N2TRUX ]</small>
Old Oct 31, 2002 | 05:53 AM
LS171Malibu's Avatar
I used them on the chevelle, and they worked out nice, though I did switch to vette accesories, which are very costly new. Another negative with the vette brackets is that if you want to supercharge, it has to be designed for the vette, and there are not many available yet. I have seen somewhere that holdens pan is front sump and can be purchased at GM dealers by part number.
Old Nov 5, 2002 | 12:09 AM
6.0s10's Avatar
Do these plates bolt directly to the frame or do the plates bolt on top of the old V8 mounts. Once the plates are in place how does the U bracket attach? I was planning on using the mounts I cut out of the donor truck I got my motor from and just welding them in place on my S-10. But if these plates are easier I will go that rout
Old Nov 5, 2002 | 12:17 AM
68LSS1's Avatar
For LS1's in S-10 check out www.leeshightechtrucks.com/
