Speedo hookups DRAC 4WAL
Old Nov 5, 2002 | 10:07 PM
LS1astro's Avatar
Default Speedo hookups DRAC 4WAL
I have been having problems hooking up my speedo when I put in my LS1.
I know the green wire is the speed signal off of the PCM for the LS1 dash but I dont know where I should wire it and if I can.
My second option would probably be better by taking the signal right off of the tranny VSS because that way I can(hopefully)hookup with the DRAC and can get my 4WAL working also. Can anybody help me with this?
Old Nov 5, 2002 | 11:12 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Speedo hookups DRAC 4WAL
Either way should run your speedo ok, but the best setup to keep your ABS happy would be: VSS to DRAC, DRAC to speedo. It may vary a little, depending upon the year of your Astro.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Nov 7, 2002 | 06:42 PM
LS1astro's Avatar
Do you know what wires for the DRAC? I dont have any good wiring diagrams so I cant figure it out.
Old Nov 7, 2002 | 08:40 PM
Speartech's Avatar
VSS --> DRAC pin 7
VSS --> DRAC pin 12
12V --> DRAC pin 9
GND --> DRAC pin 8
4WAL OUT DRAC pin 10
SPEED OUT DRAC pin 14
__________________
www.speartech.com
Old Nov 9, 2002 | 05:38 PM
LS1astro's Avatar
Damn thanks, but do you know the colors?
