ABS
Old Nov 9, 2002 | 02:56 PM
LS1astro's Avatar
Default Re: ABS
I dont know why you would wanna remove it but yeah it should still work.
Old Nov 9, 2002 | 09:20 PM
6.0s10's Avatar
Default Re: ABS
Well I am building the truck as a show piece and want to do away with a lot of the stuff under the hood. Such as ABS, A/C and maybe even the power steering. Not only am I building it for show but I also want it to perform. The motor is estimated to be around 440 RW Hp and I plan on using around a 200 shot of N20. So I figured buy removing some of the clutter it would look a lot nicer and would help me lighten up the truck.
Old Nov 10, 2002 | 12:08 AM
6.0s10's Avatar
Default ABS
I am in the process of putting a Ls1 into a 95 S-10. The truck was quipped with RWAL brakes. For this conversion I do not want to use the antilock system. IF I reconnect my power break booster. And remove the antilock wiring/controller will my brakes still work properly with the ABS stuff removed? Or do I need to buy a different non-ABS setup?
Old Nov 19, 2002 | 01:34 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Default Re: ABS
i have a 94 truck i installed an ls1 into and after i bypassed the antilock system my brakes did funky things, for example, my right blinker doesn't work when i push the brakes, but does when i let off.
everything will work ok (brakes and stoping) but you may run into some problems like i did.
http://www.ls1truck.com
allen
