Extruded Aluminum Fuel Rails
I was just looking through some of the stuff on LPE's website and came across some things some of you might find useful. They have aluminum extruded fuel rails for about $18.00 a piece (12" length). The injector bosses were around $90.00 for a set of 8. This is a little cheaper than the other aftermarket setup, providing you can finish them yourself. Otherwise SpeedInc's setup might be cheaper in the long run. They also had saginaw to AN adapters. I assume the GM style quick disconnects are the "saginaw" fittings they're talking about.
