Silverado V6 to a V8
Old Dec 30, 2002 | 02:45 PM
scubastifler's Avatar
Default Silverado V6 to a V8
I have a 2002 Automatic Reg. Cab Silverado 4X4 with a 4.3L V6. I was wanting to drop in a new V8 crate motor if possible. I am new to conversions and was wondering what parts are needed to complete this ordeal. I also would like to know all about conversions so any help would be nice. I am wanting to get all the torque I can out of the engine and will be using the new motor in the mud as well as the street. So what is the best motor to drop in my truck, 8.1 or 502 Crate motor, GM 6.0, or the GM 5.7. Please let me know all you know and all you need for the conversion.
Thanks
Steve
Old Dec 30, 2002 | 09:22 PM
John B's Avatar
Moderator
Default Re: Silverado V6 to a V8
No to be disrepectful but why on earth would you want to convert a 2002 truck to a V8 when you'd just be better off and spend less money just buying the truck with the V8 in it from the factory? What am I missing here?
Old Dec 31, 2002 | 02:07 AM
Come on i take a lot of **** but my dad knows the dealer so we got like $8,000 off the V6 because it was the last in stock. But we are willing to work at converting it after saving $8,000 because we can do more.
Thanks,
Steve
I need a lot of help tring to figure out what supplies i need for the swap.
Old Dec 31, 2002 | 06:16 AM
pmg's Avatar
pmg
Rather than trying to collect a bunch of pieces, you might be better off to find a V8 truck that was rolled up in a ball and merge the 2 trucks.
Old Dec 31, 2002 | 01:57 PM
CashDudeHomie's Avatar
Find a 6.0 and PCM out of a wrecked 3/4 ton. It should bolt in easier and you will run into a lot less problems. I would recommend posting on the truck board, someone there has surely tried this or knows someone who has.
Old Dec 31, 2002 | 03:04 PM
Thanks for the advice. Any other help would be appreciated.
Thanks,
Steve
Old Dec 31, 2002 | 03:05 PM
Thanks,
Steve
Old Dec 31, 2002 | 05:49 PM
LS6BEAST's Avatar
Buy a rolled over LS1 Trans Am or Camaro from Ebay for around $3750 and get the Silverado V8 harness from www.GMdirect.com for around $275. You will have more then enough parts to build your V8 truck with an all aluminum engine. You will also save weight. A 4x4 V8 Transmision from a the newer Silverado is also pretty cheap on Ebay around $450. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Old Dec 31, 2002 | 05:51 PM
LS6BEAST's Avatar
WWW.GMPARTSDIRECT.COM
Old Jan 1, 2003 | 02:59 AM
That is exactly what i need to ******* do. Does anyone know anyone or has anyone done a engine swap with a V6 to a V8 Camaro or Trans AM engine. I appreciate the help and all i need to do is get all the parts and strat hunting.
Steve
