fuel filters
Old Dec 31, 2002 | 08:19 AM
67ls1CamaroProject's Avatar
Default fuel filters
Do you need to run a fuel filter on both sides of the pump? Even though I have a screen on the pickup in the tank? Also, do you need a sump or can the Mallory 110FI pump pull the gas through from the top if I mount it lower than the tank?
Old Jan 1, 2003 | 08:39 PM
Boosted One's Avatar
Default Re: fuel filters
On my setup I ran the Aeromotive A1000 with a 16 gallon feul cell. Inside the cell I put a sock from an intank GM pump on the bulkhead adapter instead of buying a $90 filter from aeromotive. I also have a 10 micron filter on the outlet side of the pump.
In my experiance pumps don't last too long when using a pickup style feed. I would put a cell in or put a sump in your factory tank.
Frank
Old Jan 2, 2003 | 12:29 AM
John B's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Do you need to run a fuel filter on both sides of the pump? Even though I have a screen on the pickup in the tank? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The screen in the tank is not a fuel filter. A fuel filter is designed to remove debri in th micron size. You need a "fuel filter" in addition to the in-tank screen!
Old Jan 2, 2003 | 08:10 AM
John,
My question was whether or not I needed 2 filters. I am aware the screen is not a filter but I thought you could filter the fuel with a 10 micron pre pump and nothing after pump. Mallory recommends 40 micro pre pump and 5 or 10 micron post pump.
Thanks for the replies.
Old Jan 2, 2003 | 08:46 PM
John B's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> My question was whether or not I needed 2 filters. I am aware the screen is not a filter but I thought you could filter the fuel with a 10 micron pre pump and nothing after pump. Mallory recommends 40 micro pre pump and 5 or 10 micron post pump.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Okay.....I just used one filter since this is the way GM does it and it seems to work fine for all factory EFI cars.
