In-tank pump or external?
What are your goals/needs? What hp level, and is it a full on drag car that will see 1.5 or faster 60' times?
If it's a big horsepower racer...do external, no doubt. The externals are the only ones that can support 600+hp on a single pump, and sumped setup is almost necessary on a hard launching car.
If it's a street car, 300-500hp, want to keep it quiet, I'd do an intank Walbro pump. FWIW, you can get an external Walbro pump good for ~550hp, for maye $120 or so. Past that, you are talking Aeromotive etc for an external, $200++.
Hope that helps
Brian, my short term goals are to get it running. It used to be a 1.70 60' big block car running 11's. My long term goal would be similar with supercharger plans. Because of this, I was leaning towards the external method which would allow me to just change the pump as my hp goes up.
Not sure how racy your car is, may want to do a cell in the trunk even.
http://www.autoperformanceengineering.com/
run by a buddy of mine, Ron Gregory. best prices I've seen anywhere for Walbro stuff. has some good pump data on the page as well.
The pump has the markings GSL 392. I picked it up from the classifieds section here on the forum for $100.
Here is a pic of the fuel pressure regulator. The quick disconnect that was cut off the fuel rail was brazed onto the fuel line and fits into the filter <img src="http://temp.corvetteforum.net/c3/70lt1//fpr.jpg" alt=" - " />
I am running an external walbro pump with a stock 99 vette regulator/filter through steel lines that I bent up to the fuel rail. I had the fuel rail modified for an AN -6 male fitting. I am still running the stock 70 vette fuel tank which just happened to have the right size supply line out the bottom and the return in the top.
"The quick disconnect that was cut off the fuel rail was brazed onto the fuel line and fits into the filter "
I too used the male side quick disconnect from the fuel rail line, but I just inserted it into the 99 vette fuel filter/regulator output port. From there I connected it to my main line using AN fittings. My concern is that the OEM fuel fitting clips do not fit in this location because the clip doesn't fit around the female fitting on the filter/regulator. Will this be a problem? The line is clamped to my frame rails so I do not think it can be pushed out of the quick connect fitting from the fuel pressure. How does the 99 vette fittings connect at this location? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
