Intake duct ideas?
Old Jan 14, 2003 | 02:40 PM
bgreen's Avatar
Default Re: Intake duct ideas?
www.airflo.com
Diesel truck stuff, you can use rubber hoses & aluminum pipe, then get some hose clamps.
They have 4" stuff, transitions, weird bends, etc.
Lots cheaper than ricey "ICEMAN" style stuff...
Old Jan 14, 2003 | 03:13 PM
LS1swap's Avatar
here is a link to my set up. I you scroll down to " the intake " you will see. it takes alittle for the pics to load on dial up.
http://www.fiero.nl/forum/Forum2/HTML/027739.html
Old Jan 14, 2003 | 06:00 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
I've used the LT1 Camaro throttle body elbow on a couple of them now. It works real well if you are needing to head over towards the side of the car.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 15, 2003 | 12:13 AM
PTnova's Avatar
hey i have a ls1 in a 70 nova and i made a dual intake set up out of 4" stainless with two k&N panel fitlers mounted on either side of the radiator flush in the rad support... it looks trick and after i finish i am going to have it all electro polished. it should look killer.. e-mail me if you want pics i dont know how to post them on here. later
Old Jan 15, 2003 | 12:47 AM
67ls1CamaroProject's Avatar
Default Intake duct ideas?
What did you guys do for the intake ducting on your hybrids? I have the donor car setup but it is not very useful. I will use the maf. What diameter hose or pipe, air filter and where you can get it will be helpful. I saw some stuff that Typhoon makes for the sport compact stuff. Do they have anything I could use? Also, how do you get the air temp sensor out of the original fbody duct work? It is the two pin connector just ahead of the MAF sensor I think.
Old Jan 15, 2003 | 08:45 AM
70 LS1's Avatar
Conversion master
I am using a C5 corvette setup that goes up and over the radiator with a K&N filter in front.
