LS1 Chevelle
I also plan to run a T56 behind the engine - will the truck computer work with the 6-speed?
I am clearly in the infancy stages of this project. ANY help anyone could provide would be greatly appreciated.
Rinky-
72 Chevelle
The computer will work. I'd suggest flashing it to a ls1 Fbody m6 operating system before tuning it.
Rinky-
72 Chevelle
The stock truck accessories work, HOWEVER... If you want to run the stock hood, go with f-body accessories. What intake are you planning on running? Anything based on the Camaro/Vette intake requires the use of the matching water pump. The truck intake can use either or water pumps(but seeing how your starting with a base truck motor just keep the stock intake, it works very well).
How much do you want to buture your car? None? you'll have to get your oil pan modified like S&P does... ATS has a snazzy oilpan thats coming out soon, but their too rich for your budget. If your fine with cutting and welding and that jazz.... BRP mounts only require a stock LS1 CAMARO oilpan/windage tray/pickup tube. Now you have to cut your firewall and have fun with intake clearance issues. Even if you want to make your own engine mounts so you do not have to cut your firewall and all that...You'll have to get a Camaro oil pan modified.
For tranny.... T-56... You'll have to "T-Cut" your tunnel. In other words, make it bigger then stock but cutting, opening, then adding more metal. Some guys can get away with bashing the living crap out of the tunnel, some can't. The stock truck harness will not work with the T-56 from what I know. If thats the case we have a few sponsors on the right of the page that can help you out with your harness needs.
From the info that I know.... You might be better off building your engine based off the iron 6.0l block, LS1 Camaro intake(non EGR), and I'm pretty sure the sensors just plug in if their Camaro/Vette/Truck...
Headers, no one currently makes a header that is worth putting on the LSX in a Chevelle. Shorties are worthless IMO. Just run a stock pair of 99-02 Camaro exhaust manifolds. They flow well and won't break your budget.(30-50 bucks) Stock truck manifolds will not work.
Any other questions, feel free to ask. If I don't have an answer someone in this section will for sure! We're a great bunch of guys in the hybrid section
-Matt
TJR
Anyone have a good design for motor mounts for a 1972 Chevelle that would allow stock LS1 F-body accessories to fit? I downloaded a design from somewhere - not sure where though...
Rinky
You don't suppose that the S&P motor mounts are required to place the engine in the required location to set the T56 correctly for easy fit? Most folks say that MAJOR tunnel surgery would be required for a T56 conversion, but S&P did it with no real cutting of the tunnel at all - just an 8" x 4" hole for the shifter. If the engine is placed to allow an unmodified oil pan and no accessory drive interference, would that place the T56 in a spot that would require major tunnel surgery?
Rinky
