ls1 into first gen (again)
Old Jan 27, 2003 | 02:05 PM
RyanJ's Avatar
SSU Moderator
Default ls1 into first gen (again)
I know it has been asked and talked about before...but i couldnt find what i was looking for.
a/c: what compressor, condensor, etc. do you use? if you use the ls1 stuff, where does it meet the 67-69 stuff? I mean, if you have A/C in a first gen with an LS1, where does LS1 meet 1967? Anyone using vintage air stuff? I'd like to keep the interior looking stock and the engine bay as clean as possible (i.e. without that hideous box in the fender/firewall area).
so, what works with stock controls and the LS1 compressor and condensor?
Old Jan 28, 2003 | 06:56 AM
67ls1CamaroProject's Avatar
Default Re: ls1 into first gen (again)
I have not hooked mine up yet but I have a reliable source that says the stock LS1 compressor works with the vintage air system. So, I have already ordered their compact unit and electric controls. I will try to keep the LS1 a/c request signal and associated wiring. I need to figure out how to change the LS1 factory fittings on the compressor and condenser and dryer. Anyone know who can weld on some AN fittings to the existing ac lines?
