Conversion Question (Driveline)
Old Jan 27, 2003 | 08:57 PM
SScott's Avatar
Default Conversion Question (Driveline)
1993-1996 T-56 will that work with an LS-1?? Im trying to install this LS-1 into an 85 Vette. I would love it if this combo would work. Im not sure it will even fit. I know Im going to need a custom length driveshaft, and Im going to have to cut the center devider (?) where the shifter goes. Anyway, also I need to change the 97 throttle by wire, to the F-body cable set up. Any suggestions would be appreciated thanks.
Old Jan 27, 2003 | 10:37 PM
John B's Avatar
Moderator
Default Re: Conversion Question (Driveline)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">1993-1996 T-56 will that work with an LS-1?? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No it won't <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
The LS1 input shaft is 0.400" diferent in length.
Old Jan 28, 2003 | 12:18 AM
SScott's Avatar
Is there anyway that could be made to work? getting the longer inputshaft?
Old Jan 28, 2003 | 10:37 PM
79ZED's Avatar
Sscott,
There are a couple of ways to go. You could use an adaptor (see the post"https://ls1tech.com/ubb/ultimatebb.php?ubb=get_topic;f=21;t=000376). This was for a 700R4, but I don't see why the adaptor wouldn't work with a T56.
The other way is more expensive: replace the bellhousing, adaptor plate, and input shaft form the LT1 with ones from an LS1. The parts are available thru TTC transmissions ( the makers of the T56) or thru GM.
John
79Z28
