Better to get vette ls1?
My frame will be notched. I am not sure if the vette LS1 eliminate the need to notch for the AC. From what I remember the ALT is the only thing up top.
Try John at speartech. He is doing my conversion.
BILL
Good luck
Its just a few pictures needs to be updated.
http://www.speartech.com/coproj-1991ls1.html
Part of the reason you have to notch and cut things is that the oil pan has a larger sump. If you get a vette engine you will have to get a pan from an f-body car (something I forgot to mention yesterday.)
-Brian C.
Bill
The only differences between the Vette and F-body LS1s are the shape of the oil pan, electronic throttle body vs cable operated, the accessory layouts, and the cam specs. Cam specs are negligible however, the C5s were just a bit different because they didn't ever have an EGR setup like the F-body and had to compensate.
Tony
