pcv question?
Old Feb 20, 2003 | 09:31 PM
69LS1's Avatar
Default pcv question?
I think we all know of the problem with oil consumption via the pcv tubes. My question is since I have no emissions connected, can I run valve cover breathers on the ls1 or does it need a vacuum to relieve the crank case pressure? Any help appreciated.
p.s. Thanks to everyone's help with my last post.
Old Feb 21, 2003 | 11:26 AM
68LSS1's Avatar
Default Re: pcv question?
You will probably get answers both ways on this one. I've done it for years on modified carbed engines with no issues. I know of a few LS1 guys using breathers and one is running a 6.0 set up. My understanding is the biggest problem doing this is loosing the positive vacuum in the crankcase which helps the piston rings seal. Maybe a little more wear with out. How much? Not enough that I'm going to worry about it.
