FOR SALE: LS1 set up for stand alone
Getting away from the fuel injection, going back old school. This is still in the car and running. Has probly about 3000 miles on her with 4lbs of nitrous run through on the 100 shot.
Motor made 331/309 to the wheels on motor through a messed up 2004r and a 12 bolt with HEAVY *** 17" wheels..
Ls1 from a 01/02 F-body
Stock rotating, crank .010/.010 with a std bore
ported ls6 oil pump
241 heads with 2.00/1.57 valves with bowl job and mild porting
comp 918 springs
TSP 228R cam
TSP hardened pushrods
ls6 intake
32 lb(36lb @58psi) racetronix injectors
stock fuel rails
Harness done by speartech
01/02 f-body computer tuned fat lots of timing good for 100shot on tune. More if a lil timing was taken out or fuel was added.
Moroso ultra 40 wires
4" induction goes with it..
Hoses that fit a stock chevelle/elcamino radiator
Custom motor mounts
Everything will go that is needed to put in and turn key except fuel pump, radiator, and headers..
$4500 obo
Any questions pm or call
940-389-0659
Kenny
ported ls6 oil pump
comp 918 springs
TSP 228R cam
ls6 intake
stock fuel rails
Custom motor mounts
$4500 obo
940-389-0659
Kenny
