T56 On 5.3L An Option?
Been gathering info and researching a conversion. Vehicle is a 2002 S10 currently with a 4 cylinder and 5 speed. Was determined to go the F-Body engine route. However, been finding a lot of NICE 5.3 packages lately for much less dough than a F-Body powerplant. I want to do a 6 speed but didn't know if the T56 would bolt up to the 5.3 liter. I'll go out on a limb here and assume (and we all know what that does) that since the 5.3 is in the LS engine family, a 6 speed would work. Please enlighten me to this possibility. Did read awhile back about a S10 that was a 5.3 and a 6 speed set up. One concern is the PCM reprogram. Since the 5.3's did not come with 6 speeds but with 5 speeds in trucks, what would the reprogram on the PCM involve? Look forward to some helpful replies or pointing me in the right direction.
Crank/Stroke on the 5.3 and the 5.7 are the same, Difference is in the bore, which the 5.3 shares with the 4.8 (but the 4.8 has a shorter stroke on it's crank).
You'll have to have the computer programmed/tuned in order to get it all to work harmoniously.
You can do it yourself, or you can have someone put a tune in for it. I'm taking an 01 PCM and having it leaned out a bit to work with the LM4(5.3 all AL) and the t56 going into my 94 rx7. I don't really expect any problems.
In fact, I'm pretty sure that I can plug in the stock computer, and have the MAF read the 5.3's draw and work appropriately.
But I'll have it reprogrammed just to make sure.
Another option is to locate a manual PCM for the truck, plug it in and go.
There isn't the input requirement on manual transmissions PCMs like there is in the PCM for an auto with the electronic 4l60 or 80e.
On the trucks there is a seperate harness than the engine harness for the MAF, MAP sensor and rear O2's that runs along the chassis. This might be only on the 4x4s I'm not sure. On the 4x4s, the VSS is located in the transfer case.
Not all of them. LS1 Intake is the worst. Ever. Stock Truck is on par with the LS6...which is 2001/2 LS1 Fbodies.
But for what it's worth, when talking about a Gen V 5.3, a T56 will not bolt up without a spacer. I know this has been posted before, but just mentioning it for future searchers.
