T56 Conversion - clutch pedal question
Looking to install a 1996 T56 tranny in a 1968 Camaro
ANy comments on using the stock clutch pedal setup are appreciated.
WHat is necessary from a fabrication standpoint?
Conversion pictures are a plus...
Thanks in advance
As far as the clutch pedal issue, we modify a stock GM master and slave to work with the stock clutch pedal. The only fabrication is taht you have to drill one hole to mount the hiem end to the pedal itself.
I guess the best thing to do is to call the shop and tell them what you are going to do and from there they can send you pictures relative to you specific questions at that time.
