fox ls1 swap. anyone use Fbody long tubes?
Old Dec 9, 2005 | 01:25 AM
TT_Vert's Avatar
Default fox ls1 swap. anyone use Fbody long tubes?
Since they are designed to clear the auto trans and bolt right in, will these work? Or will I have steering shaft issues? The motor is still in the car, just thinking ahead for possible hurdles ill have to overcome.
Dave
Old Dec 9, 2005 | 07:06 AM
Brains's Avatar
Where you'll have issues depends on which headers you choose. They're all a bit different, but so far every one I've test fit has had clearance issues. Haven't found one header that clears as-is.
Old Dec 9, 2005 | 10:18 AM
TT_Vert's Avatar
ok thanks. Do you think a FMS shorty header w/ an ls1 flange would fit ok? THis way I have access to the trans much easier, plus I think it may bolt right in (aside from flange)
Dave
Old Dec 9, 2005 | 01:02 PM
Brains's Avatar
I actually want to try a set of MAC's for an F-body. I think they'd be pretty close to fitting. Just can't find a set locally ..
Old Dec 9, 2005 | 01:05 PM
TT_Vert's Avatar
i need to see who makes these ones in this car.
dave
Old Dec 9, 2005 | 11:26 PM
01PewterWS6's Avatar
https://ls1tech.com/forums/conversions-swaps/338338-mustang-ls1-headers.html
Look at Lane's posts, hes done the swap before...
Old Dec 9, 2005 | 11:30 PM
1dirtyZ's Avatar
what about the pace setter headers?
Old Dec 9, 2005 | 11:33 PM
TT_Vert's Avatar
those are the ones I have actually.
Dave
Old Dec 10, 2005 | 01:09 AM
1dirtyZ's Avatar
how do they fit??
Old Dec 10, 2005 | 01:27 AM
TT_Vert's Avatar
they're still in the fbody Ill have the drivetrain out as soon as i can find a place to story my 2 cars in the garage now. We have 8" of snow on the ground too
Dave
Old Dec 10, 2005 | 12:33 PM
Brains's Avatar
I fit a set of pacesetters, and they ALMOST fit without any issues. Just need to reroute a couple pipes, and set the motor down in the frame a little lower.
Old Dec 10, 2005 | 05:31 PM
92CamaroReallySlow's Avatar
Where is there fitiment issues with normal Fbody headers on the Fox-bodies? I wonder how a set of Hawks Thirdgen Longtubes would fit. Although it would be an expensive trial and error. I would offer mine to try a fit if I wasnt too lazy to take them off.
Old Dec 10, 2005 | 07:24 PM
red90cobra's Avatar
brain I tried a set of mac they woulnd't fit. They went right through the steering shaft.
Old Dec 11, 2005 | 01:18 AM
TT_Vert's Avatar
well your in itasca im in elgin, not far
Dave
Old Dec 11, 2005 | 02:54 AM
If my garage isnt too wet, maybe we could set something up over my winter break.
Old Dec 18, 2005 | 05:29 AM
1dirtyZ's Avatar
i just reread your post brains, you mentioned lowering the motor a bit AND reroute a couple of pipes? is that neccisary?
