mustage swap questions
Old Dec 16, 2005 | 12:22 AM
black4x4's Avatar
Default mustage swap questions
I have been thinking about doing a 6.0L and th350 swap into a foxbody and was wondering how difficault it is on a scale of one to ten. also i was wondering if i needed to change any of the front suspension or if stock would work? How do you go about wireing do you use a mofified factory harness or what? and what about the radiator can iuse the stock mustange one or do i need something else? finally how does the fuel system workout in one of these swaps.
Old Dec 16, 2005 | 07:23 AM
Brains's Avatar
Of all the threads about Mustang swaps, I think you could find the answers to most of these questions by reading.
As far as the level of skill required, what is a 1 to me might be a 10 to you, so its pretty hard to gauge. I think its about as easy as you're going to get when it comes to conversion cars. Everything nearly bolts right in.
Old Dec 16, 2005 | 11:58 PM
1dirtyZ's Avatar
with all the people thinking about ( and the ones actually doing ) you'd think some one would come out with a kit for this swap!
Old Dec 17, 2005 | 12:00 AM
1dirtyZ's Avatar
so branis, any updates? you havn't updated your site in quite a while....
Old Dec 17, 2005 | 12:12 AM
black4x4's Avatar
If i would get a wiring harness from speartech it should perrty much be a plug and play setup once it was tuned.
Old Dec 17, 2005 | 12:31 AM
TT_Vert's Avatar
the wiring is really easy actually.
Dave
Old Dec 20, 2005 | 02:36 PM
1dirtyZ's Avatar
another thing to note is that you can't use the ford 4.6 motor mounts and modify them a bit to work with the iron block ( on the alu. block there are 6 mounting holes that can be used , but on the iron block there are only 4and the ones that are missing are the ones you need). so your best bet is to use a conersion k member and motor mount conversion plates to run the old style motor mounts.
Old Dec 20, 2005 | 03:18 PM
SRS's Avatar
SRS
Hey guys..... I wanted to introduce myself. I am the GM of Streetrodstuff.com and we offer a service to design and build radiators in absolutely any size or configuration you need. We started this service mostly for the guys building antique cars with motor swaps, but we want to get into any and all kinds of motor swap applications.
Take a look at our site or give us a call at 330-358-0004.
Take care!
Old Dec 20, 2005 | 10:01 PM
black4x4's Avatar
so ineed the sbc k-member along with the lsx mounts for it to put a iron block in.
Old Dec 21, 2005 | 03:12 AM
1dirtyZ's Avatar
yup!
srs , good to have you here!
Old Dec 22, 2005 | 01:11 AM
black4x4's Avatar
What about brakes is the stock booster in a 4cyc vacuum or hydro. i plan to run manual steering, and no ac so i figured i would only need to deal with the alternator as far as exceesories go or will i need the power steering pump to for the brakes.
Old Dec 22, 2005 | 01:24 AM
red90cobra's Avatar
power steering pump is fo the steering only brakes are seperate
Old Dec 22, 2005 | 02:45 AM
black4x4's Avatar
so the brakes are vacuum boosted or what?
Old Dec 22, 2005 | 06:48 AM
Brains's Avatar
Yes, brakes are vacuum.
