f-body PS pumps???
Old Dec 16, 2005 | 09:33 PM
datsbad's Avatar
Default f-body PS pumps???
Guys I am fitting up my new intake from australia. on the air boxes it has outlets . one is hitting the PS pump cap. Is there any other GM vehicles out there that use the same pump but with a smaller resivoir ?
Old Dec 16, 2005 | 09:59 PM
67RSCamaroVette's Avatar
got pics? why dont you ditch the airbox?
olly
Old Dec 16, 2005 | 10:02 PM
datsbad's Avatar
CANT DITCH THAT , kinda screws my plans up !
Old Dec 16, 2005 | 10:10 PM
do you have pics of your setup? are you talking about that funny E- shaped plastic thing that the IAT goes in? I think it's off an F-body, it came with my LS1. That thing hit the trash before the tie - downs came off the engine. It's ugly and pretty hopeless, i hope we're not thinking along the same lines.
olly
Old Dec 16, 2005 | 10:13 PM
datsbad's Avatar
I tried to post a pic but it wont let me . And no I am not talking about that thing . hold on , let me try to downsize a pic !
Old Dec 16, 2005 | 10:15 PM
ah are you talking about that sweet individual throttle body setup? with the dual pipes leading out of it? In that case, you might wanna look at a corvette setup. I believe you can re-locate the resevoir if you want.
Old Dec 16, 2005 | 10:17 PM
http://www.ls1howto.com/howto/c5/hea...psassembly.jpg
ditch the lines, clean up the bracket, and it'll look good
http://i14.photobucket.com/albums/a3...y/LS1Vette.jpg
theres a pic of it on an engine...
olly
Old Dec 16, 2005 | 10:20 PM
datsbad's Avatar
now your thinking !!! if i remove the res from the pump , i am fine . but how do i get a line to stay in the hole where the res was . i dont mind runing an external res but how will the line attach ?
Old Dec 16, 2005 | 10:21 PM
datsbad's Avatar
I am thinking a GTO pump will work !
THIS PIC IS A LITTLE BLURRY . SEE WHAT I MEAN ?
Old Dec 16, 2005 | 10:26 PM
Gto pump looks like a f-body pump with a funny resevoir, i havent really found a good pic.. i bet a C5 one would be easier to find though.. You could mount it wherever you wanted, too.
http://highperformancepontiac.com/te...to/index.html#
olly
Old Dec 16, 2005 | 10:52 PM
datsbad's Avatar
link no worky!
Old Dec 16, 2005 | 10:59 PM
http://pontiac.jbcarpages.com/GTO/20...O%20Engine.jpg
very similar to 'vette one, but has clear resevoir.. also! you don't have to relocate the alternator, and was built for the LS2....
olly
Old Dec 16, 2005 | 11:04 PM
datsbad's Avatar
holy **** , perfect pic . thanks . i know that is a ls1 motor . the pumps i here on the ls2 are a little different. that will work then i can run a remote mount res. thanks
Old Dec 16, 2005 | 11:06 PM
Good luck on the 'camaro!
olly
