Will the length of plug wires affect anything?
Old Dec 20, 2005 | 09:06 PM
datsbad's Avatar
Default Will the length of plug wires affect anything?
Hello , I am mounting my coil packs inside the car(69 camaro) right behind the firewall. I have made some brackets to hold them up behind the ac box . I want to know if you think the plug wires running under the headers and behind the motor into the coil packs will have any effects on the car running properly ? I dont think so myself and i have spoken to others about it . Just wanted to see what some of you think ?
Old Dec 21, 2005 | 09:45 AM
Oscar Will's Avatar
As I understand, the only detriment to longer wires is slightly more resistance and as long as you keep the coil packs a reasonable distance from the plug you'll never feel any difference. I know several hot rod types (coupes & sedans) with LS-1 power that have interior coil packs to "clean up" the engine bay........not a problem. I left mine on the motor....because I like the "nuts & bolts" look and at shows most casual bystanders look at that LS-1 and say...."what the hell is that?...a motor out of a helicopter"?????
