cut through fuel lines on engine?
Old Dec 21, 2005 | 10:52 PM
FastKat's Avatar
Default cut through fuel lines on engine?
I am pulling an LS1 out of a 99 Z28 and I don't have the special tools required to take off the fuel lines. The lines go to the AIR unit and the fuel rail. Should I just cut these, or will I be forced to use them down the road?
Thanks, -Dave
Old Dec 22, 2005 | 12:08 AM
Stu Cool's Avatar
The fuel line tools are not expensive, you can get them at most auto parts store for about $10 for a full set that will work on multiple sizes. The ones I have came in a kit of 5 different plastic disk shaped devices. You may find good use for the fuel lines later, I would avoid cutting them if you can
Pat
Old Dec 22, 2005 | 12:44 AM
red90cobra's Avatar
r u talking bout the rubber line connected to the fuel rail? your gonna need that if you using stock rails
