Any Turbo Kit for Hybrids
I have a 1991 Jeep Wrangler that will receive an LS1 transplant. Will any of the single or twin turbo kits fit in there.
It will be without A/C. Just the alternator and the power steering pump.
Will a single turbo kit for F-Body or even LS1 truck fit the Jeep.
It's a sand Jeep, so, I am not worried about axles because sand traction is forgiving. It will be mated to TH350. Will have to get the truck oil pan and oil pump pick up tube.
I am thinking to get forged pistons and rods 348ci and T76GTS turbo but didn't decide on bolw off valve and waste gate size cause it will be open headers, no cats or mufflers.
I guess it makes a differnce when selecting a waste gate size if it's open header doesn't it?
I am looking for 800 RWHP. Is it possible with say 16 psi boost out of a T76GTS.
Its an OBX 2.5" in/out. As for the motor, I haven't started on the build but am also open there -- so many options that will all work just fine, I'll cross that bridge in a couple months. I'm leaning towards a run-of-the-mill low compression 348 though, for the cost factor. -Alex
