LS1 to 3rd gen oil pan question
Old Dec 25, 2005 | 11:07 PM
350-Z28's Avatar
Default LS1 to 3rd gen oil pan question
I got into stripping down my LS1 and finally got it off the pallet to remove the oil pan and got to thinking it might not work. It's going into an 84 Camaro, and came out of a 2000 Corvette. Is this oil pan useable on the 3rd gen swap or would I need a 4th gen pan or aftermarket? What other things should i look out for with this swap? Is there any modification needed to the sub frame of the car? Just general heads up sort of stuff. Thanks for the help ahead of time.
Old Dec 25, 2005 | 11:56 PM
ThirdGenLS1's Avatar
i'm pretty sure you'll need the pan from the f-body
Old Dec 26, 2005 | 03:49 PM
350-Z28's Avatar
Thanks much, will look into that. Think by any chance they have a drag/road race oil pan available via aftermarket?
Old Dec 26, 2005 | 10:03 PM
Dave88z's Avatar
A 4th gen camaro/T.A. pan will work. I am using the pan that came on my LQ4
6L truck motor. The only diff is that the truck pan holds an extra quart but will hang down lower. This is not a concern to me so I will use it.
Old Dec 27, 2005 | 04:30 PM
Teetoe_Jones's Avatar
We make an aftermarket road race oil pan for the LSX engines. It has a 4 way trap door baffle, -10AN oil cooler lines, and 2 -4 AN plugs for oil returns for twin turbos/superchargers. It comes with the fabricated pan, oil pick up tube, new GM gasket, and oil pan stud kit for $499.
Tyler
Old Dec 27, 2005 | 06:52 PM
kairles's Avatar
Tyler
and what company is this I may have to order one of those in a couple months
Old Dec 27, 2005 | 10:13 PM
350-Z28's Avatar
I agree what company, and it should work with my 3rd gen swap right? I was debating running dry-sump but if this comes with all the goodies I might stick it out with wet sump.
Old Dec 28, 2005 | 12:41 AM
Does my sig only show up on my screen?
The company is American Touring Specialties, our website is www.t56kit.com, and our # is 702-245-6305
Tyler
Old Dec 28, 2005 | 01:08 PM
MrDude_1's Avatar
just FYI, the stock pan has an excelent extensive baffeling system and a nice windage tray...
so unless you're building a extreme G machine, you wont see any oil control problems from the stock fbody pan...
just savin ya a few bucks.
Old Dec 28, 2005 | 08:15 PM
kairles's Avatar
Tyler
it wasn't working yesterday but I clicked on the "X", but I didn't see it listed on the site
thanks for the info, im sure I'll be callin you guys in a couple months when Im buying turbo stuff
Old Dec 29, 2005 | 07:08 AM
350-Z28's Avatar
Unfortunately I'm going all out on this build, I doubt stock is an option. I plan on over 1000 HP and running below 10 seconds. These are all plans subject to change up until I purchase the part. But I'd like to squeeze as much power out of that engine as is possible.
Old Dec 30, 2005 | 10:48 AM
Hulk hogan's Avatar
Well if you get 1000Hp than you should be well below 10 sec but the stock pan should still be fine! I wouldn't spend the money on that unless I had to!
Old Dec 30, 2005 | 10:54 AM
MrDude_1's Avatar
i didnt want to be the guy to say it twice until someone else did, but yea.
the stock pan is fine waay past 1000hp.
if you get the chance to see one, you'll see what i mean... its built better for performance usage then any other OEM pan ive ever seen.
thats why theres no aftermarket fbody/vette/truck pans.... the only aftermarket pans are for engine swaps.... and of thoes, over half are modded stock ones. lol
Old Dec 30, 2005 | 05:35 PM
350-Z28's Avatar
Thanks for the tip, still looking into dry sump gotta see what it would take and if it's too outrageous then I'll go after the stock F-body pan.
Old Dec 31, 2005 | 05:22 AM
NemeSS's Avatar
if anything u SHOULD stick with the stock oil pan
being that its a structural part of the block
more so in the alloy block
most of the aftermarket pans are just fabbed from aluma sheetmetal
too thin to reinforce structure i would think
i assume ur gonna use a tubular k-member
shouldnt have any oil pan to k-mem. clearance issues
maybe with a 1000 hp u can be the first ls1 conversion 3rd gen
to run 8's or kwiker
betta move kwik tho
cuz i know a guy whos building a 402 8:1 1/2 in head bolt/stud
etp headed, solid, roller blow thru turbo setup with a 850 dp carb
with a precision 101 mm turbo
it "should" make 1100+ on pump gas AND METH injection
also i understand hes using a main girdle with a stock f-body oil pan
in a 85 camaro with 9 in rear
GL
Old Dec 31, 2005 | 10:49 AM
350-Z28's Avatar
Didn't know that, thanks for the tip, I'll be looking into some more mods for suspension and body a little later on after the car is stripped and I see what i need to save for. My dad is a distributor through speedway so i might be able to get a k-member through them hopefully.
Old Dec 31, 2005 | 01:03 PM
TJ's Avatar
TJ
the vette pan will work if you have a tubular k member.
a PA/Profab unit anyway.
you will need the vette pickup and windage, which im sure you have if the pan is on the motor.
id test fit it before spending money on another one.
good luck!
Old Jan 1, 2006 | 04:17 PM
350-Z28's Avatar
Thanks, I'll be looking into tubular k-members soon and if I can get the vette oil pan to clear then i'd keep it and save the extra cash. It did come out of a corvette so I have all the necesarry oiling elements. Thanks again for the luck.
