ls2 for the 76 vega begins
I'm going from 110 octane only high CR motor to a nice starting pump gas modern motor.
Going to start out pretty stock but I'm looking for a big cam. Daily driving isn't a concer of mine. The car is probably under or around 3000lbs and my main goal is go as fast in the 1320 as a cam'd ls2 can go in this weight of a car.
Any cam suggestions?
Also I'm a little lost when it comes to PCM and harnes. I just need enough to run the thing without breaking the bank. Do I just use a stock PCM and harness and not hook anything up that isnt needed to run the engine?
Here are some pics of the car.
http://www.rocks-hideout.com/vega/
Its gonna be fun. Need something to do during these Michigan winters.
Bill
Ill definitly drop you email here sometime, thx
Wiring harness and PCM to make this work are my biggest hurtles. It will be my first time not going old school on an engine. Should be fun.
