donor radiator or stock?
Old Dec 26, 2005 | 11:48 AM
Tyj's Avatar
Tyj
Default donor radiator or stock?
Im installing a 6.0 in a 72 suburban and was wondering if most of you guys are using a stock radiator out of the recipient vehicle or if i have to go with the donor cars radiator.... Id like to use a aftermarket stock aluminium but dont know if i'll have inlet/outlet problems some help would be great
Ty
Old Dec 26, 2005 | 12:44 PM
Bo185's Avatar
The stock 72 V-8 one should work.
The outlets should be the standard v-8 location inlet on top drivers side and outlet on pass lower side. The stock late model truck rad. may be to wide.
Summit has what ever rad. you could need for a swap for cheap!
Old Dec 26, 2005 | 07:25 PM
GTS346's Avatar
can you run a copper/brass radiator with the aluminium LS1 engine?
Old Dec 26, 2005 | 08:27 PM
Bo185's Avatar
I don't see why not, I would just flush your radiator fluid more often if it sets alot and use the orange rad. fluid!
Old Dec 26, 2005 | 10:07 PM
Dave88z's Avatar
Just don't forget to plumb in the lines off of the heads. They are used to bleed air from the system and ran into a nipple on the LSx radiators. Run a search and you will find a few solutions.
