How to tell the difference between 98 and 99+ interior harness?
Old Dec 30, 2005 | 06:13 AM
derekf's Avatar
Default How to tell the difference between 98 and 99+ interior harness?
Like the title says.
My understanding is that 98 is pretty much a one-off deal so far as the harnesses go.
I've got an interior harness but it's up in the air as to whether it came from a 98 or a 99.
Are there differences so far as the interior harnesses go, and if so is there an easy way to tell which year harness I've got?
Old Dec 30, 2005 | 08:19 PM
99LS1_TA's Avatar
If you look at the connectors that go behind the passenger kick panel. (the ones that the engine harness plug into). The 98 will have three connectors, a blue 10 way, a White 10 way, and a white 8 way. The 99-02 harnesses will only have the two connectors, A Blue and a White 10 way.
Old Dec 30, 2005 | 08:56 PM
derekf's Avatar
Thanks; the harness is not in a car so it took some digging to find the appropriate connectors.
I do have a blue and a white 10-way connector and no white 8-way ... but a couple of inches closer to the BCM in the harness is a black 8-way connector. Is that used for something completely different in the 99+ harnesses, or would that just be a matter me having a 98 harness that happens to have a black connector for some reason?
Old Dec 30, 2005 | 09:15 PM
99LS1_TA's Avatar
There is a black 8 way connector that is probably six inches from the blue and the white connector. That connector is on the 98's and the 99-02. It plugs into another harness that goes to the passenger door.
