1995vert To Ls1 98 Small Problem?
Old Jan 1, 2006 | 09:47 AM
lilicedout24's Avatar
Question 1995vert To Ls1 98 Small Problem?
OK PROBLEM IS MY TRANSMISSION CROSSMEMBER IS NOT MATCHING UP DO I NEED ONE FROM A LS1 98 T/A OR A CUSTOM ONE MADE MY CAR IS A 95 t/A VERT
Old Jan 1, 2006 | 10:45 AM
gogogadget's Avatar
I have the same problem. I am using a stock crossmember that is modified to fit a TH350. For mine all I have to do is re-drill the hole used in the adapter plate (it is a B&M kit). For now I have the trans mount bolt out with the crossmember bolted up and the trans just sitting in place. You might try that and see if you can drill another hole once everything is in place. Mine was only 1/4" different from the LT1 location.
Old Jan 1, 2006 | 02:45 PM
joking511's Avatar
What tranny are you using? A crossmember from a LS1 car wont work . The floorpan is different . My T56 bolted right right up to a crossmember from an LT1 car .
Old Jan 1, 2006 | 07:22 PM
I Have The 4l60e Came With The 98 Ls1. So Do I Need To Drill The One From My 95 Lt1 Or Get One From A 98 Ls1?
Old Jan 1, 2006 | 08:12 PM
joking511's Avatar
I guess your only option is to use the 95 xmember. One from a 98 wont line up with the body bolt holes.
Old Jan 2, 2006 | 01:35 AM
Oh Ok Ill Tryagain Tomorrow Thankx For Your Info
Old Jan 2, 2006 | 01:20 PM
joking511's Avatar
Let us know how it goes .
