LQ4 into a Jeep CJ
Thanks
I think Street and Performance has put a GenIII into a CJ... or maybe it was a *****'s Jeep, not sure. Check them out at www.hotrodlane.cc - they have some nice project car pics.
I'm hoping to find out if the corvette pan works. If it does and I can find one cheap, you can have the truck pan if you need it.
Aaron
The 'Vette pan uses a specific pickup tube and windage tray. Won't work with the truck stuff, so plan on changing it.
Also note that there are 4 different 'Vette pans. Two versions of the C5 "batwing" pan (one with removeable bottom, other as 1piece casting, otherwise interchangeable) and then the C6 wetsump pan (used on LS2,no batwings, just a "normal" looking pan), and the new LS7 drysump pan (I bet its expensive). I expect that the pickup tube and tray are different between the C5's and standard C6's (but don't know that for certain). You'll need to check. I'm not sure that the C5 batwing pans would be a good choice for off-road use, too much wide flat surface to have to protect with skidplates (IMO).
'JustDreamin'
Let me guess...the rear main bearings were why you had to change 3 engines in the 1978 Jeep.
Thanks,
Aaron
