LS1 RX-7 FD Won't Crank
I have a swapped a 1998 LS1/T56 setup into my 1993 Mazda RX-7. Everything is hooked up and the car won't crank, since it's not getting spark and the injectors aren't firing when the starter is turning over. At first I thought this might have meant a bad Crank Position Sensor, so I installed a new one. This netted the same result as before. I then wired up an OBD II port into the Camaro engine wiring harness and tried to pull the codes, but the code reader displayed an error when hooked up. Thus, I concluded this meant I had a bad PCM, so I bought a tuned PCM off of Jesse Bubb figuring this would cure my problem. I hooked it up last night and went to crank the car and the battery had low voltage but was delivering spark when cranking, yet the car wouldn't crank. The battery was then placed the charger to let it receive a decent charge before trying again. When I went to go crank the car again with a full charge there was no spark while the starter was turning over and you couldn't here any clicking of the injectors. You can here the fuel pump kick on when the key is in the ignition and there is fuel going to the rails. The pink wire at each ignition harness has 12V power while cranking and the black at the harness has good ground continuity. Last but not least, when I went to pull the codes off of the new PCM, I got another error message.
One thing it does do, is it sparks when turned to the on position and it sparks again, when the car is turned off. Is this normal for a 1999 PCM to do this as my buddy's 1997 C5 doesn't do this?
I am now a little stumped since I have tried two CPS's and PCM's and experiencing the same problems.
Has anyone ever encountered something similar? Thanks in advance!
I do have a 1999 F-Body PCM and wiring harness connected to a 1998 Camaro Z-28 LS1/T56, so the pinning is correct. I guess I could try and short the starter power to its solenoid, which would be similar to wiring in a "Start" button, just to see if that would work.
Thanks for all the ideas guys, please keep them coming!
Brad
To test it... put the key in the on position, and take a wire and jumper the big power of the starter to the little post (start signal) and see if it turns over....
-Jason
PS - how is the voltage on your battery? Also, get an ammeter and check the resistance from your block to the frame to make sure you have a GOOD ground.
I haven't been able to add the remote starter (jump the starter) yet, as my work schedule is crazy, but I will be hooking that up tonight and will fill everyone in on those results.
THANKS!
Brad
Thanks for all the suggestions.
Man does this thing sound mean with open longtubes!
