Power steering hose to PS pump
Old Jan 9, 2006 | 01:42 AM
pt67camarols1's Avatar
Default Power steering hose to PS pump
I did my power steering plumbing with braided hose and have a problem.
What can I use to hook up the braided hose to power steeing pump? Are there any fitting there that I can use on the stock plastic line that out of the pump?
Old Jan 9, 2006 | 05:34 AM
LS1GMCTruck's Avatar
Thumbs up Yes...
If you have a GM steering box & P.S. pump...Then yes, Eaton/AeroQuip has steel o-ring adapter fittings that thread into both. They offer two different metric sizes. Both thread sizes adapt to -6 male AN. This is what I used. Gar
Old Jan 10, 2006 | 04:19 PM
5.3 racer's Avatar
if you are referring to the plastic nipple on the resevoir you can slide your braided line over the nipple and hose clamp it, you can also get one of those decorative hose ends that has a hose clamp inside it. it is a return line, very low pressure.
