Light cars good for swap??
#42
I have alienated folks on stangnet by throwing out the thought of an LSx engine into my '65 fastback. Much better suspension parts are being developed, and the car could be built ~2800# with some creature comforts. Ever since I bought my GTO I have fallen in love with these engines. I DID get some classic mustang guys to admit that the LSx is a lot closer to what my car came with than a modular motor!!!
Realistically I probably won't do it to this car, basically due to the underlying value of the old fastbacks...but it is fun to think about!
#47
Originally Posted by Cop Car
i have a two door chevette that is set up for a buick 3.8, pm me if anyone is interested in the car (id be selling it for around $300) it would be a great car to put an LS1 in
#48
Originally Posted by LC2nLS6
I vote for a 1967 MG BGT with an LS2. Might have to tub it and put in a narrow 9 inch rear.
Josh
#49
Originally Posted by Nemesis9
Do an LS1 Mini Cooper. You can take out the front seats and sit in the back like Hightower from Police Academy.
(sorry for the old pic- the car is closer to being done now... not a whole lot closer, but we're gettin' there.
#50
Originally Posted by Sabre002
Yes would have to do something to get anything bigger then a 205 out back. All I got out back on my 74 MGB GT are 195/60/14 on the stock roadstyle rims. and there is not much room for any more with out a Sebring body kit out back or moving the leaf springs in some for more room. But with they 195 Falken tires it hooks really well even with out a LSD out back, and it is no toruble to drive it in the rain but with a LS1 something will have to be done. I'm going to work on getting a LS1 into my MGB GT after I finish my LS1 FD here or some boost for the Rover motor.
Josh
Josh
#51
You could always do a ford focus zx3 , donors are to be had cheap and they sell a kit for a rearend and cradle for a ford motor that could be easily modified to hold a ls1.
http://www.tcf-v8-focus-conversions.com/
#52
Originally Posted by Laxx76
Hey I've been reading the forum now for awhile and thought I would finally post up. Now just so i don't get flamed on I have used search and come up empty handed. My question is what are the good light cars (2700 or under) to use for the swaps? I know about rx7's and 240's as well as the 944 porsches but I was curious if anyone else could make a recommendation? I know a fiero could be used but I do not trust the transmissions at all. I'm lookin to build a fun unique car that will be dependable and see plenty of duty in the texas sun. Miata's are out as well as I am 6'4 and I have fitment issues. My goal is to do a fairly clean swap for 10,000 or less doing most of the work myself except for fabrication.
But lightweight to me means 700-1200kg (1540-2640lb). The Triumph TR7/8 would be a reasonable candidate for something different yet usable. As it's a pretty strong platform and well proven in compition (rally and circuit). You'd have to fab up how to mount the engine as the original mounted to a seperate subframe which I doubt would be possible with an LSx engine.
Other idea's are would be an AC Cobra replica. One of these even with a 502ci big block is easy to get below the 1000kg mark (2200lb). Plus there are some really good kits out there that use very good chassis' (race proven) with modern IRS setups.
If you want something wacky then try a Caterham like style car. This is a Dax rush:
![](http://www.cckbell.f9.co.uk/images/car2004.jpg)
It's sold in the UK as a complete car or as a kit and there is a variant designed for a V8. 700kg (1540lb) I would think is possible. However keeping it on the ground and not in the air may prove more of an issue.
Essentiall if you want lightweight and rwd you need to look at classic British sports cars. The Mazda MX-5 (Miata??) Is pretty decent also, but just about anything else on sale if fat and heavy, especially once you get a V8 and heavy duty gearbox and drivetrain into it.
Or as a final suggestion, maybe something old school like a 32 Ford 5 wind coupe (think American Graffiti). It would look way cool, but handling probably wouldn't be it's strong suit.
#54
I'm new here, but I think the answers to your questions will all be found at torquecentral.com in the applicable section, FASTERthanYOU.
There's some really good threads on here about it as well and a couple searches should bring up a ton of information for ya. Sorry I can't be more help, but I'm on dial-up and searching for threads takes me a ton of time.
This thread is really giving me some good ideas, though. I'm selling my Lightning and planning on picking up a 3rd Gen RX7, Porsche, or Colorado/Canyon to put an LSx into.
I really like the idea of the RX7, they're beautiful cars, and seem to be really, really good all-around performance vehicles with a LS1. A Porsche would be unique as hell, but I'm not sure what kind've hurdles I might run into trying to do it. An AWD Colorado/Canyon could be really cool too, though.
Not enough money, haha. So many projects I want to do.
#57
I've seen a big block Mini (proper Mini not German imposter). It was converted to rwd and you sat on the back seats
It also had a blower and a big bug catcher hood scoop like a top fueler.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#58
Originally Posted by zexel
The 88 - 91 325IS had a heavy iron block OHC I6 and it weighed 2800lbs. The 4cyl versions started at 2400lbs, though the M3 version is 2800lbs. The y handle pretty good and have independent rear suspension - the same as used in the Z3/M Roadster (320hp), so a beefy diff can be found. My dream is a 2700lb E30 with 400hp LSx/T56.
If this guy isn't lying about his weight, then my goal should be easy.
http://www.r3vlimited.com/board/showthread.php?t=60661
-Yes! Second-gen 3er! I've got my '88 325 down to 2700 lbs with a full tank of gas. LSx'd e30 with be SICK.
-Oh, btw, read the BMW m60/s62 VS GM Ls1 fight on that link. It kinda funny and sad too...
