C1 C2 computer connector pins
Old Jan 18, 2006 | 09:07 AM
MattP's Avatar
Default C1 C2 computer connector pins
I tried using the search first. It is returning very few threads.
Where can I buy just the pins so I can recrimp the wires to a shorter length for my conversion? Thanks
Matt
Old Jan 18, 2006 | 11:14 AM
Oscar Will's Avatar
INFO - NEW PCM CONNECTOR SERVICE KITS #83-81-32 - (Sep 16, 1998)
SUBJECT: INFORMATION - NEW POWERTRAIN CONTROL MODULE (PCM) CONNECTOR SERVICE KITS
MODELS: 1996-99 ALL PASSENGER CARS EXCEPT GEO AND CATERA
TWO NEW KITS HAVE BEEN RELEASED TO SERVICE THE POWERTRAIN CONTROL MODULE (PCM) CONNECTOR IF THE CONNECTOR HAS BEEN DAMAGED DURING SERVICING. THIS PCM HAS AN ALUMINUM BODY AND IS USUALLY MOUNTED UNDERHOOD.
KIT (P/N 12167308) CONTAINS THE 80 WAY CONNECTOR BODY, THE COVER, TWO EACH OF FOUR DIFFERENT TERMINAL RETAINERS AND 25 EMPTY CAVITY PLUGS. NO TERMINALS ARE INCLUDED.
IF TERMINALS ARE NEEDED, USE P/N 12084913 FOR .35 MM AND .50 MM WIRE AND P/N 12084912 FOR .80 MM WIRE. THESE TERMINALS ARE INCLUDED IN THE TERMINAL REPAIR KIT J 38125A OR B, AND REPLACEMENTS CAN BE ORDERED FROM KENT-MOORE.
KIT (P/N 12167313) CONTAINS ONE CONNECTOR SEAL. WHENEVER THE CONNECTOR IS UNBOLTED FROM THE ALUMINUM BODY OF THE PCM, THE SEAL CAN STICK TO THE BODY, OR MAY BE TWISTED. THIS SEAL SHOULD BE REPLACED WHENEVER THE CONNECTOR IS REMOVED IN SERVICE.
PARTS INFORMATION:
P/N DESCRIPTION =============== ====================================
12167308 KIT, PCM HARNESS REPAIR
12167313 SEAL KIT, PCM CONNECTOR
12084912 TERMINAL
12084913 TERMINAL
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
Old Jan 18, 2006 | 01:55 PM
MstgKillr's Avatar
Which COVER are they refering to? Is it the two grey plastic covers?
Old Jan 18, 2006 | 02:28 PM
Oscar Will's Avatar
They are referring to the grey plastic covers.
Old Feb 9, 2006 | 01:17 AM
71Convertible's Avatar
Does anybody know if the empty cavity plugs are available individually? If so, what's the part number?
Thanks
