Slave Cylinder Connector
Old Feb 6, 2006 | 02:08 PM
Happy Jim's Avatar
Default Slave Cylinder Connector
Hi,
Any idea where I can get a clutch slave cylinder quick disconnect connector from? (with or without line).
Can do a photo if required?
Thanks
Jim
Old Feb 6, 2006 | 02:11 PM
2001CamaroGuy's Avatar
do you want the line side or the slave side? I got a new line from McLeod Clutch.....from what the tech guy said they have all kinds of stuff.......
Old Feb 6, 2006 | 02:28 PM
Happy Jim's Avatar
It's the Slave side I'm after, I need to connect it into my own master cylinder. Do you have any contact details for them?
Many thanks
Jim
Old Feb 6, 2006 | 05:57 PM
just look up McLeod Clutch and call their tech line......tell them what you are looking for and they will get you to the right person (what they did with me)........
what I ordered was a steel braided line that had an AN fitting on one end (4AN I think) and the stock LS1 male quick dissconnect on the other....
Old Feb 6, 2006 | 11:22 PM
Argon Z's Avatar
lots of companys make them but they are 100 bucks.
Old Feb 7, 2006 | 09:08 AM
MattP's Avatar
ADD-716130TJ
Advance adapters fitting for a TJ. You can buy it for 16.95 at summit. Fits perfectly. All you need then is the -3 hose from the slave to the master cylinder.
Old Feb 7, 2006 | 11:25 AM
Originally Posted by MattP
ADD-716130TJ
COOL.....wish I had known about that.....
Old Feb 7, 2006 | 01:42 PM
rao's Avatar
rao
http://eshop.advanceadapters.com/com...roduct_id=1864
Old Feb 7, 2006 | 02:36 PM
Happy Jim's Avatar
WOW - Awesome, many thanks guys
Jim
Old Feb 7, 2006 | 07:22 PM
Argon Z's Avatar
you said quick disconnect. That is not a quick disconnect, just a fitting. Is that what you were searching for. If so all i did was to weld a fitting on the stock line. Do a search for my past posts about this topic to find a pic.
Old Feb 7, 2006 | 09:25 PM
Slo_240sx's Avatar
LoL Argon Z and his welded line. You posted that in my thread about the same thing last month and I said to myself "No I don't think so" lol.
This is the guy you want if it is -6AN. Part # jif-31406 from jiffy tite off summit.
JIF-21404 is for a -4AN. can anyone confirm if it is a -6 or -4? I believe its a -6.
What Matt P posted was not the slave side but the master side. That uses a roll pin to hold it in.
-Alex
Old Feb 7, 2006 | 11:01 PM
MattP's Avatar
This fitting is for the slave side. There is a roll pin there also. You must take the transmission off to get at it. This totally eliminates the quick disconnect, but I don't care because the price is right. I have pictures if someone would like them.
Old Feb 7, 2006 | 11:03 PM
MattP's Avatar
This is the wrong one
This is the correct one
http://eshop.advanceadapters.com/com...=1139373863609
Old Feb 8, 2006 | 08:38 PM
Numbles's Avatar
Someone should add this info to the sticky for the t-56 swap guys.
Old Feb 9, 2006 | 01:56 PM
RiceKilla's Avatar
I have one that came off of my 2002 Ls1 swap, thing is the nipple thats comes off it to connect it into the line is crushed at the tip. It looks like it got crushed when they, the salvage yard, cut the line.
