? spacer for corvette bracket
Old Jan 19, 2006 | 12:58 PM
jdeuel87's Avatar
Default ? spacer for corvette bracket
I have an LS1 from camaro and would like to keep the existing crank and water pump pulleys. I will not have AC, only using power steering and alternator. I have a corvette main accessory bracket with alternator and power steering pump. Can I use a spacer for this bracket and if so how long does it need to be...What should I use for tensioner in the upper passenger side...I would prefer to use the items I have rather than drop large$ on custom set-up...Thanks LS1 going into 67 Corvette
Old Jan 19, 2006 | 01:38 PM
Mark IXZD 150's Avatar
The Corvette belt rides 3/4" closer to the block than on the Camaro.
