3rd gen and ls1 02 sensors?
Old Jan 26, 2006 | 11:00 PM
LS1rscamaro's Avatar
Default 3rd gen and ls1 02 sensors?
is it real bad to run the ls1 with out any o2 sensors ? i know the give a read out to the ecm when to lean out the fuel and the air mixture
Old Jan 26, 2006 | 11:56 PM
StevenK's Avatar
Ummm.....you can't run a FI motor without an o2 I thought.
You can run just 2 though, I've got the rear o2s tuned out in the ECM
Old Jan 27, 2006 | 12:56 AM
92CamaroReallySlow's Avatar
No the car will run without 02 sensors. I started my engine with only one sensor plugged in (I only had one at the time). However the computer I believe will not go into closed loop, from my understanding...correct me if Im wrong. I dont know if it is bad in terms of causing any damage, but I would probably avoid long term use without O2 sensors. For short term to see if the engine will run, it should start up.
Old Jan 27, 2006 | 07:40 AM
RFERG43's Avatar
I have been running with only the passenger side O2 sensor for about 2K miles (apparent bad computer input). I examined one recently and it appears the car is running somewhat rich. Lots of black carbon.
