LS2 or LS6
Old Jan 30, 2006 | 09:00 AM
cwm1515's Avatar
Default LS2 or LS6
I was curious as to which one most of you would prefer for a swap. They both make in the 400-405 HP range so which one would you rather have and why.
Old Jan 30, 2006 | 09:18 AM
NOS USER's Avatar
LS2 = 6 liter
Old Jan 30, 2006 | 09:32 AM
jyeager's Avatar
LS2 is cheaper when purchased as a crate engine.
LS2 has a bigger bore so the valves are less shrouded which equals more power potential normally aspirated.
If needing a custom tune on a factory PCM, the aftermarket hasn't cracked the latest crank reluctor wheel. So you have to stick with the stock tune for now...if using an aftermarket engine control system I think support is there.
LS2 uses the drive by wire. I assume for your retrofit you'd have to convert to cable operated throttle. I don't know what's involved, but it's probably not a big deal.
I think the easiest swap is to get an LS1 salvage that includes computer, harness, transmission as well as all accessories and brackets. Then you can cam/head swap this to get over 400 hp. The total cost for the horsepower is better, plus you can custom tune that PCM.
Old Jan 30, 2006 | 01:49 PM
Stu Cool's Avatar
LS6 uses it too. I don't understand why everyone thinks you have to convert back to cable throttle from and ETC system. I am actually going the other way with my swap, changing to the Drive By Wire. The ETC is well proven, even in high performance applications. It makes cruise control available without additional hardware. It also gives the capablity for traction control if you want to go that way. It eliminates the need to have a hole in the firewall for the throttle cable. Lots of reasons to use it.
Pat
Old Jan 30, 2006 | 03:01 PM
jyeager's Avatar
Right, but retrofitting the pedal might not be easy? I suppose that's not really an issue with someone who's fabricating a custom engine installation though.
Doesn't this require the OEM computer? What if you were using a BS3, Gen VII, or FAST system as your computer controller? Don't know if any of those handle the drive by wire.
Otherwise, I agree with all of your assessment.
