Starter wiring
I hooked up my starter today and tried to get the motor to crank but nothing happened. I don't have the main harness hooked up to the motor yet. I just have the factory 6.0L battery cables: positive going from the battery terminal, to the junction block (to alternator), and to the starter. Even though the motor won't start unless the harness and PCM are connected, I thought the stock K5 starter solenoid wire comming from my ignition switch would at least make the starter work. Am I retarded?
