9 inch housing in a 68 camaro rear brake ????'s
Hey Fellows,
My question is "Has anyone used the rear disc off a 4th gen(ie2000 Z-28) on a 9 inch housing,if so WHAT HOUSING ENDS DID YOU USE??
I am in the process of having my housing narrowed and I have a wrecked Z that I am going to use the rear discs. I needed to know if I could use the Big Ford Ends or is there a different housing end that would make it a simple bolt up?
Thanks
Thanks
I have a nine inch Ford with Camaro rear brakes. The housing ends came from DTS and allow my GM brakes to bolt on. You just have to make sure that the plates are properly spaced so that the caliper is centered over the rotor. GM has F-body shims specifically for that purpose.
