The Jimmy is 90% Complete
Old Feb 8, 2006 | 08:55 AM
Jones'n's Avatar
Originally Posted by ls6jimmy
the only problem with putting a elbow is if I turn to the right that is where my overflow tank for the radiator is going and if I turn to the left I don't know if I will have enough room b/t the power steering resevoir and upper radiator hose for any type of CAI system. Any idea's are gladly appreciated.
Thanks for all the compliments
Most of the time people run an elbow to the passenger side and either relocate the battery, or go under the battery.
Old Feb 8, 2006 | 03:33 PM
ls6jimmy's Avatar
Originally Posted by Jake the SSnake
I didn't know they made a 3 guage pillar for our trucks where'd you get it?
http://www.racingdimension.com/brows...Gauge-Pod.html
Old Feb 8, 2006 | 09:14 PM
XtremeDime's Avatar
u think that it would fit in a 99? it says 94-98.
XtremeDime's Avatar
heh. guess u got an 01 so yes
Old Feb 9, 2006 | 05:48 PM
blazerls1's Avatar
Sandersons Shorty Block Hugger's
Do you have the part number for these headers?
Old Feb 9, 2006 | 06:22 PM
Jake the SSnake's Avatar
JTR is one of the few places that carry them, 1 1/2 primaries and 2 1/2 collectors barely better than stock manifolds.
Old Feb 9, 2006 | 07:42 PM
Bimmer Tech's Avatar
Relocate the battery to the frame rail, use a 90* elbow after the TB. You should have plenty of room then.
Old Feb 10, 2006 | 02:52 PM
low03noma's Avatar
Hey, can you tell me if you mounted the motor as low as possible, and which oil pan setup you went with ( 5.3 shortened or not? or camaro pan?) Cause im in the middle of swapping in an ls1 but the truck is going to be body dropped so i need to know how much room there is between the top of the motor and the bottom of the hood??
Old Feb 10, 2006 | 03:20 PM
MrDude_1's Avatar
that looks kickass.
as far as the air intake goes, id run a short radius 4" to 3.5" 90* elbow like whats on my car, put the MAF on it, then run the air intake to the fender, behind the battery.
done right, theres just enough room. and it would look cool.
Old Feb 10, 2006 | 03:21 PM
MrDude_1's Avatar
another option is to the side, then straight down, down low, next to the frame rail... if this is a street only truck, thats a real option.. if it sees offroading at all, id keep it higher.
Old Feb 10, 2006 | 03:56 PM
XtremeDime's Avatar
you can go anyway u want low noma. u can notch the frame for the 5.3 pan or buy a ls1 swap oil pan. you can even cut and reweld the 5.3 or camaro pan to clear the cross member. depends on how bad u want it. you can get the pan shortened for less than a 100$ while the swap pan is around 400.
Old Feb 10, 2006 | 06:56 PM
  #32
ls6jimmy's Avatar
I had a custom chromoly k-member made and I used a truck oil pan.
Old Feb 11, 2006 | 12:35 AM
  #33
low03noma's Avatar
i know that you can do it all of those ways but because of the body drop im not sure if i can clear the hood with the engine. Is there 3 inches between your hood and motor?
Old Feb 11, 2006 | 11:26 AM
  #34
ls6jimmy's Avatar
I have about 7-9 inches
Old Feb 11, 2006 | 03:50 PM
  #35
XtremeDime's Avatar
any way should work unless you totally f up the motor mounts position. you might want it higher up in teh engine compartment cuz i know i dont like my oil pan hanging down there that low.
Old Feb 11, 2006 | 03:51 PM
  #36
XtremeDime's Avatar
how much are u lowered anyhow? im lowered 3.5/4.5
Old Feb 11, 2006 | 11:05 PM
  #37
low03noma's Avatar
If your asking me how low i am, i lay rocker with air ride and a body drop.
Old Feb 12, 2006 | 02:51 AM
  #38
XtremeDime's Avatar
you should be fine with clearance.
Old Feb 12, 2006 | 08:54 AM
  #39
kossuth's Avatar
Truck is turning out well. Again as for the elbow you have other options. Here is what I did on my truck. You don't see the filter but I just relocated the battery to the bed in my case. If that is the way you want it then thats cool, but if you want it done alittle different here is an idea. I got the elbow from the local International big truck dealer.
Old Feb 12, 2006 | 09:30 AM
  #40
ls6jimmy's Avatar
Originally Posted by kossuth
Truck is turning out well. I got the elbow from the local International big truck dealer.
Thanks; you got a part number for that elbow and a phone number for that I'ntl. Big Truck Dealer.
