The Jimmy is 90% Complete
Old Feb 7, 2006 | 11:50 AM
ls6jimmy's Avatar
Default The Jimmy is 90% Complete
Here is some pics. She started up without any leaks.
Attached Thumbnails The Jimmy is 90% Complete-dsc00323.jpg   The Jimmy is 90% Complete-dsc00337.jpg   The Jimmy is 90% Complete-dsc00338.jpg   The Jimmy is 90% Complete-dsc00316.jpg
Old Feb 7, 2006 | 12:04 PM
mr. peepers's Avatar
That looks awesome man. Any more details on the engine/tranny setup? Congrats
Old Feb 7, 2006 | 12:13 PM
RedlineBrian's Avatar
I used to have a jimmy. Ahh the memories. Have fun with that man. You should get about the same gas mileage as your old 4.3 too. lol
98Z28MASS's Avatar
Damn that is sick, and yea what are you using for a tranny and rear?
Old Feb 7, 2006 | 12:58 PM
ls6jimmy's Avatar
Tranny is a built 4L60 and a 9" Ford. Thanks for the compliments.
Old Feb 7, 2006 | 01:03 PM
Jake the SSnake's Avatar
Did you cut down the 9 inch or use an aftermarket housing?
Old Feb 7, 2006 | 01:11 PM
ls6jimmy's Avatar
Had it narrowed. Here is a couple more pics
Attached Thumbnails The Jimmy is 90% Complete-dsc00318.jpg   The Jimmy is 90% Complete-dsc00319.jpg   The Jimmy is 90% Complete-dsc00326.jpg
Old Feb 7, 2006 | 01:24 PM
I think you just solved my intake routing problem.Instead of picking up cold outside air,just spray the hell out of it!Btw what did you use for headers?
Old Feb 7, 2006 | 01:30 PM
Mikey 97Z M6's Avatar
Thumbs up
Awesome install man!!
That's a really tight fit with that air cleaner/maf setup in front of the rad. though. You going to have enough flow through that little air filter? I think I would have opted to put a 90 bend directly off the TB and put the MAF off to the side. A setup similar to the new GTO's would look pretty slick on there with a cone style filter off to the side.
Again, that engine looks awesome in there, good job.
Mike
Old Feb 7, 2006 | 01:37 PM
LOL,,, nevermind my previous comment about flow on that filter element. Did some rough calcs and it looks like that filter has about twice the "flow area" as your MAF so you're sitting pretty good.
Mike
Old Feb 7, 2006 | 01:38 PM
Yeah funny you should mention that, i've been wondering how close the gto setup would be
Mike
Old Feb 7, 2006 | 01:43 PM
ls6jimmy's Avatar
Sandersons Shorty Block Hugger's
Old Feb 7, 2006 | 10:16 PM
lt4malibu's Avatar
thats awesome, im considering doing an lsX swap in my 99 jimmy. any build-up pics?
Old Feb 8, 2006 | 06:51 AM
Jones'n's Avatar
Mike
Lots of airflow sure... but all the air will be hot as hell. Would be much better off with a elbow and a filter located elsewhere. Only time won't matter is with the nitrous.
speaking of which, I wonder if the engine will fatigue quicker going from the heated air of the engine compartment, to getting blasted with cold nitrous. Never seen any kind of write-ups on that one.
Old Feb 8, 2006 | 07:24 AM
smokinHawk's Avatar
nice build, but i think your seriously choke off your engine with that filter.
it looks like you have enough hood clearance for a taller intake, id either switch to the 6.0L intake and put the filter up higher away from the radiator, or preferably switch to a single plane intake with an elbow and drilled for injectors. you can turn the TB to the left or right if needed, though with it being in the centar of the intake you should have enough roomdo put a desent filter on it., plus the aluminum intake would work well for your directport.
Old Feb 8, 2006 | 07:56 AM
ls6jimmy's Avatar
the only problem with putting a elbow is if I turn to the right that is where my overflow tank for the radiator is going and if I turn to the left I don't know if I will have enough room b/t the power steering resevoir and upper radiator hose for any type of CAI system. Any idea's are gladly appreciated.
Thanks for all the compliments
Old Feb 8, 2006 | 07:57 AM
ls6jimmy's Avatar
Yeah tell me what you want to see and I can email it to you b/c I get tire of shrinking the pic to post on here.
Old Feb 8, 2006 | 08:12 AM
ls6jimmy's Avatar
just trying to figure out this host thing
Old Feb 8, 2006 | 08:44 AM
hellbents10's Avatar
LS1Tech Sponsor
Very nice!!!
Old Feb 8, 2006 | 08:52 AM
I didn't know they made a 3 guage pillar for our trucks where'd you get it?
