Old Feb 24, 2006 | 07:50 PM
john kilgore's Avatar
Default 5.3
l have a 5.3 04 motor that l want to use as a trans dyno. the harness seems complete but does anyone know what l need to make it run. l have a feeling that converting to a carb won't be any cheaper. thanks john
Old Feb 24, 2006 | 09:33 PM
pwrtrip75's Avatar
the pcm, 12 volts, and fuel. Its all pretty simple, plug and play. theres posts in the sticky with what wires you connect to batt and Ignition, or switch. You'll need to wire a serial port into it. You will need to disable VATS in the pcm. (vehicle anti theft system)
