Water Pump
Old Feb 25, 2006 | 05:42 PM
AmericanMuscle313's Avatar
Default Water Pump
Will a 6.0L water pump work with vette or F-body acc. drives in a 1st gen f body?
Old Feb 25, 2006 | 05:46 PM
01PewterWS6's Avatar
No, the spacing out from the block is different between all the setups, f-body, vette, truck5.3/6.0...
You need the correct water pump for the accesories, if you have it all, toss it on and youll see...
The vette is the closest to the block, then fbody, then truck sticks out the furthest...
Old Feb 26, 2006 | 02:19 PM
pwrtrip75's Avatar
and the radiator hose neck sticks straight up on the truck ones and will hit the throttle body on a ls1 intake.
Old Feb 26, 2006 | 05:28 PM
BLWN1's Avatar
This would have been nice info a month ago... guess I looked in teh wrong places. I think easiest will be using truck acc, and a carb style intake....
Old Feb 26, 2006 | 06:59 PM
Im doing the same on mine right now...(carb intake, truck accesories, only because they came with the motor, id rather have f-body or vette to tuck them closer to the motor)
Old Feb 26, 2006 | 09:32 PM
BLWN1's Avatar
Which intake did you go with? Elbow I assume?
