Cheapest place to remove VATS?
Old Mar 1, 2006 | 03:32 PM
jeepinpete's Avatar
Default Cheapest place to remove VATS?
Hi all, first post. I've been lurking for awhile gathering info for a 5.3L swap I have planned for my Jeep. I intend to keep the engine stock and retain all of the emissions equipment. So to my understanding, the only thing that I need done to the PCM is have VATS turned off. I can't see paying $300+ for what amounts for 15 minutes of work, if that. So anyone have a inexpensive sources?
Thanks,
Pete
'79 Jeep Cherokee, soon to be Chevy powered...
Old Mar 1, 2006 | 04:51 PM
crewchef's Avatar
Try www.lt1350.com, that's where I got my VATS bypass module. Connect three wires and you're done.
Old Mar 1, 2006 | 05:08 PM
Jones'n's Avatar
The truck PCM's don't have the ability to just "wire in a module" the VATS system is controlled through the serial data information so it has to be programmed out.
Might try wait4me, I hear they are cheap with stuff like that.
Old Mar 1, 2006 | 06:16 PM
ls1stang's Avatar
I used wait4me to do my programming, he did a good job on the tune, and had a fast turn around time.
Jamie
Old Mar 2, 2006 | 09:58 AM
jeepinpete's Avatar
I dropped a line to wait4me, Jesse wrote back that its only 20.00 and 8.10 for return shipping for VATS removal. Thanks for the tip...
Old Mar 2, 2006 | 11:41 AM
Scooter70's Avatar
If you find someone local to you with HPTuners for the year & vehicle type of your PCM, I'm sure that they'd do it for a beer or two. It might help if you filled in the location information in your profile so we know where you live.
Old Mar 2, 2006 | 11:42 AM
Scooter70's Avatar
How are the truck PCMs different? The hardware's the same, right?
Old Mar 2, 2006 | 06:23 PM
Jones'n's Avatar
The hardware is the same, but the trucks use serial VATS, and the F-bodies use a signal from the BCM. Just different programming.
