Random stuff - Mustang trans Xmember
Old Mar 7, 2006 | 09:03 PM
Brains's Avatar
Default Random stuff - Mustang trans Xmember
Took a couple pics tonight, figured I'd post this for the heck of it. This is the transmission Xmember I built for my Mustang. A bit out of the ordinary from most Mustangs, as I'm not using the factory mounts at all. I welded in box tubing from rocker panel to rocker panel that extend through the floor and stop on each side of the transmission. Then I built the removable section that bolts to those "stubs" and the poly trans mount.
Old Mar 7, 2006 | 09:16 PM
aram's Avatar
Looks slick!
I just bought a 1992 notch 5.0 to do a LS1/4L60E in and I checked your site for help.. thanks for putting it up.
.. is there any reason a modified stock crossmember wont work?
Old Mar 7, 2006 | 09:34 PM
Brains's Avatar
It'll work fine -- but if you look at my pics above, you'll see I tucked a pair of 3" in/out high-flow cats right on the ends of my long tubes. That wouldn't be possible with the factory mount, so out came the air chisel
Most everyone else who has done this conversion has used the stock crossmember I believe. I just gotta be different...
Old Mar 8, 2006 | 12:53 AM
1dirtyZ's Avatar
nice job man!
now how about a site update!
Old Mar 8, 2006 | 08:23 AM
Brains's Avatar
How about me actually getting some real work done on the car Been spending all my "spare" time working on LS1Tech instead I'll be back at it pretty soon though, I need to take pics of the rats nest of wires... lol
Old Mar 8, 2006 | 09:50 AM
MrDude_1's Avatar
i donno what you did, but it(the site) is running faster today...
...go work on your car.
