Failed emisssions and no codes....
Old Mar 8, 2006 | 07:41 PM
cal99's Avatar
Default Failed emisssions and no codes....
I just failed the sniff test due to very high HC values. All other readings were in range and no check engine lights (now or in the last year or so). I searched LS1 tech and google and can't find too much. So far my current theory is either O2 sensors, Maf dirty from K&N residue, or vacuum leaks.
Any advise on where to look or start would be greatly appreciated. Also, I am in Houston, so if you know of a good tuner shop to check things out, let me know.
Thanks in advance,
Colin
BTW...I have a 2000 LQ4 6.0 in a 1987 land cruiser FJ60
Old Mar 8, 2006 | 07:56 PM
gen 3 bu's Avatar
high hc is a sign of excessive unburned fuel.
check for a leaking injector, regulator, dirty maf. also check the long term fuel trim with a scan tool.
Old Mar 8, 2006 | 08:08 PM
cal99's Avatar
Thanks for the input!
How would one check for a leaking injector or regulator?
