Malfunction light worked then stopped...
What else can I add. I turned the key on and put a tester on the wire coming off of the ECU, the wire on the factory harness, not the length I had to add on and I get nothing.
Thoughts?
Edit: Also with the Drive By wire TB.... When the key is on the "On" position but the engine isn't running the TB should not move when the pedal is moved correct?
-Matt
Josh-
Another thing that comes to mind is the MIL lamp. I'm using a regular incandescent bulb, the factory uses a regular bulb also, and you're running an LED. Not sure of the specs, but if the LED puts less resistance on the circuit than a bulb it may damage the driver.
